Thanks Dave, my gasket come with 4 fiber gaskets they say to put one on both sides of the valley pan is that a good idea or not ?
Go ahead and use both. It won't hurt anything and you will get an assured intake port seal. One of the problems with aluminum intakes is that they tend to flex more than a steel stock intake and this can cause problems getting a good seal. Using the fiber gaskets compensates for any problems with sealing. Be sure to use a bead of RTV at corner of the fiber gasket where it meets the steel valley cover at the ends of the valley rail as there can be a small void left there using the fiber gasket.
