I'm not sure what you mean. Is there something special to tightening up the harmonic balancer?When you're tightening up the bolt on the harmonic balancer remove one of the spark plugs and insert a rope in there and tighten away read that trick on here somewhere
Now that I have started moving things around I have broken several brittle vacuum hoses, and I am sure that was part of my rough running issue.
Has anybody got any suggestions for cleaning up parts for paint? Brake cleaner and an air gun/rags only do so much.
Oven cleaner works pretty good on grease and grime.Has anybody got any suggestions for cleaning up parts for paint? Brake cleaner and an air gun/rags only do so much.
I use a screwdriver or punch and a hammer to drive the seal out from the back side. I hammer the seal in with either a socket the size of the seal or piece of pipe or a seal driver. I do this all the time though.My question is: What seal remover and installation tool should I buy to pull and replace the front main seal, assuming its leaking (and will replace even if it isn't).
Engine was painted last night. The car is mostly together, except some of the accessories and belts. I lined up the new timing gear how the old one was, and then turned it to line up the dots. The old one had jumped a tooth. Also solving the puzzle of what bracket goes where has been difficult. On Monday I will replace a lot of the visible vacuum hoses, as I discovered that they are all hard as a rock and break with minimal effort.
I also have a question. When I put the transmission cooler lines back to the radiator, do they need the air taken out somehow?
I was planning on making a car specific thread with pictures of my work done here. I havent taken the time to do it yet. Ill go out now and take some pictures. I have a few of the process too.How about some pictures of your work.
Here is a link to the new thread with pictures of the job.How about some pictures of your work.
I saw it but haven't had a chance to read it all yet.Here is a link to the new thread with pictures of the job.
My 1972 Newport: a true survivor car
