The disc brake pistons do retract when pressure is released. If they didn't, they wouldn't release. What they do is not retract all of the way, on the earlier generations of disc brakes, always with a light drag against the rotor. This helps initial brake response and helps keep the rotors dry in damp weather. From about '81 on (on some models), the pistons would retract more for less drag against the rotor, but quicker apply functions.Disc brakes by their nature have a lot of drag at rest. The pistons don't retract. When going down the road the few thou of end play in the wheel bearings allow the rotor and hub to move enough to push them back and make clearance.
Kevin
Funny that we went from the earlier 4-piston calipers (same number as on the Corvettes for many years), to the simpler single-piston calipers, and now we're back to 4-6 piston calipers for better braking performance. The Corvette guys started to sleeve the piston bores so the durability issues of pitted piston bores were decreased. Progress?
