moper
- Joined
- Nov 15, 2010
- Messages
- 816
- Reaction score
- 448
Got any ideas besides raising the compression ratio? Would going to dual exhausts be worthwhile? I would not be opposed to going to headers, either. Would a later transmission that locked up in 3rd gear be worthwhile?
I don't think I ever got over 14mpg on this heavy car.
In terms of economy and power there are some things that will always pay solid returns for minimum investment. Here's what I'd suggest:
1. Make sure tires are inflated to maximum (printed on the sidewall)
2. Make sure the front end parts, alignment, and rear drum brakes are good and ropy adjusted.
3. Update the ignition. If you do not have lean burn - install a performance centrifugal advance curve and make sure the ignition components are good. If you have lean burn, invest in a modern distributor with integral multi-spark setup. I like MSD but there are others that all will be better than what you have. Whicever you ce, make sure it has vacuum advance on it, or settings in it. Base timing settings I'd want are 16* initial, 20* centrifugal all in by 3Krpm, and as much vacuum advance as you can get.
4. Install a performance air fliter assembly. It will sound cooler, you'll get power and mileage.
5. Install true dual exhaust system. I like loud *** mufflers but that's me. There are plenty of sound bytes to help you choose. You only need a 2 1/4" pipe, but 2 1/2 is fine too.
6. Rebuild and super tune the carb. Make sure the floats are right, air bleeds are clean, etc etc. You can slightly richen the jets by drilling, and rods by sanding. Adjust the rod hanger and air door.
7. Learn to drive more steady. A lot of gas is wasted by driving habits.
