Ok to summarize, I know my initial timing is at 10°BTDC and my vacuum advance works. Just took the car out for a nice long run with the newly installed Champion spark plugs and a full tank of 93 octane gas with Ethanol stabilizer added. Really runs like a top overall but unfortunetly still has the partial throttle "fish nibbling" feeling going on at light throttle under load. I've noticed it will do this even at low speeds (10-15mph) as well as highway light throttle cruising (45-50). But at any given time, increasing the throttle a notch makes it go away.
Id like to confidently turn down the path of looking into a possible fuel system issue. It really seems like an issue with the transition circuit of the carburetor. (The 2 barrel BBD was rebuilt last fall by a reputable rebuilder in my area.) Fuel filter was replaced also at that time.
Has anyone had experience upjetting these carbs by one size larger then factory? How about different size metering rods?
By the way I noticed a metal electrical Male spade connector on the carb near the throttle linkage that is not connected to anything. What is this for?
