ACR Nick
Im currently restoring a 70 fury 3 convertible and I noticed that there was not a kit made specifically for the C body stub frame, nothing that works in conjunction with stock parts anyway. I have seen whole kits that drastically change the suspension which delete the torsion bars, changes the stock steering, upper and lower control arms, different bump stabilizer thats usually some type of coil over replacement.
The point though is that I've taken a very universal kit and figured out how to mount the bags in such a way that with the proper fitment, has some holes drilled in the upper control arms for the airbag base on the front end and Ive fabbed a support that does not rub or otherwise interfere with anything on the front end. You need 2 inch wheel spacers, but on stock sized rims and white walls, you dont have to modify the body at all. The wheels have a sunken in look from the factory and the spacers do wonders for this cars profile and stance on the road. I know some of you cringe when hearing, 'stanced,' but i promise you its nothing like your grandsons honda. I just mean it gives the front and rear a much needed wider profile with the stock spacing that makes the wheels look like they're hiding.
For the rear, we are eliminating the leaf springs in favor of a 4 link suspension kit that's a brainchild of a collaboration between my pops and I thats based on another very universal 4 link kit. The biggest modification here is installing the brackets that hold the 4 link bars and relocating the e brake braket because its in the way on the drivers side. I'll post pics of a finished product in a few weeks. Im just seeing who has a c body, stub frame and may be interested in something like this.
Ever since starting work on this car, I've found that finding anything for this stub frame that is the backbone of the last big convertibles like the 70 fury 3 verts and the chrysler 300 verts is more of a 'good luck,' type of situation, or use your brain, welding machine and 4 and a half inch grinder and figure it out.
Oh, admittedly, I am going to have to modify the inner fender wells to fit the top side bag brackets but that isnt anything major structurally.
I just knew the moment that I looked at this stub frame that it wasnt going to be a good idea to completely eliminate the torsion bars, and being as how this particular fury took a pretty hard hit on the drivers side long before I was born, I was hesitant to order a suspension overhaul kit that was likely going to give me fitment issues anyway. I ended up reinforcing the main frame tubing on the drivers side, so the design I came up with is made to fit the actual dimensions of the frame its being fitted on.
Well, my painter has the car now and I'm currently refocusing on getting my machines set up to sew 4 cows worth of white leather into a totally refreshed, brand new interior.
Putting out some feelers on interest in something like this and also hoping someone has a good set of 70 fury 3 tail light covers for sale, or just a good drivers side light cover.
Pics incoming once my guy is done with paint! Excited to see thia old bird coming back together!
-Nick, ACR
-Nick, ACR
