3175375
Coil wire broken?
Coil wire broken?
Not even that, just have to bend one tab of the switch a little to "repair" the normally closed circuit of the relay.Coil wire broken?
The Heineken and bitterballin is on me next time I'm in Amsterdam lol.......or maybe some stroop waffles in the Albert Cupt market mmmmmDon't sweat it, happy to help.
This ^^ makes the most sense to me as nothing else was touched. Recharged the AC and all was working as it should after the valve replacement. Dumb luck more than skilled repair I am afraid.perhaps the seized valve caused the cold engine lockout to remain engaged
My 69 300 the whole dash frame had to come out. Only 4 screws and two bolts and a thousand things hooked to it.You did a better job of studying the diagram than I did. I missed the water valve on there.
You don't actually "pull the dash" on a formal, as the dash frame is welded to the body. You should have good access to most of what you need to get to by removing the dash pad, which is pretty easy. In most respects, dash related work is much easier on a formal than the earlier cars. I pulled the entire ATC vacuum harness out of our '78 NYB way back when I was 17 or 18 years old, and I don't remember having any difficulties getting to anything once the pad was off.
Jeff
