Hi, Everyone! My 77 NYB has new brakes: new master cylinder, rebuilt booster, new brake lines, new calipers, new wheel cylinders and new pads/shoes. The parking brake auto release was working well through all of this work, I could depress it past a few clicks and it would stay down until I shift the column into a forward gear - just like it was designed. It has quit working, I no longer hear the signature short his when I shift into park, nor can I depress the brake more than an inch or two. It certainly does not stay down even the very short distance I can depress it, nor can I hear any clicks. It just quit working all of a sudden. My immediate suspicion is that either a vacuum hose has come loose somewhere or has a leak. Does anyone have some experience with this issue? I will check all the hoses underneath the dash to the intake manifold port this weekend. Beyond that, I cannot find any manuals that describe in detail how it is designed so I can diagnose further. The drum brakes and the emergency cable were installed properly, I took pictures before and after to verify installation. I would prefer to fix it rather than just disconnect it.
Thanks in advance!
Thanks in advance!
