Battery Tray
vdk2010
Frankfurt, Germany
Just a friendly FYI.
I was searching for the correct 1969 Imperial Battery Tray. It's different from the Chrysler Tray because of the 28" Radiator. After searching for a while I found out that 1966-1969 B-Bodys used the same Battery Tray then the 1969-1971 Imperials.
I bought one from Vans Auto (#CHBTY669) to check if it's indeed the same and it is!
The Hold Down Kit is #CHZBRK669. But it's already listed for the 1969 Imperial.
Thank you Julian, that's valuable information, I didn't know that!
Not wanting to be anal about things, but I think the washer nut on the J-bolts of the hold-down kit on the right are original to an Imperial application while wing nuts are supplied with the aftermarket battery hold down kit.
Correct. A Washer Nut is OEM correct and I will use a new one instead of the wing nuts! All parts on the left are what came with the hold down kit from Vans Auto.
