commando1
Edelbrock dual plane low riser Performer....Has to fit under the stock 75 Monaco hood and that's about it...
From what I was reading it seemed like the higher the lobe separation the more choppy the idle was, and I'm looking for just a bit more lopey that stock. Unless I completely mis-read the articles on summit and comp cams. And I'm not sure exactly what you were saying at the end, was that a recommendation for a set-up? I thought earlier you recommended buying the cam and lifters etc as a set, which is why I was looking into the aftermarket options.
Your choice of cam will change according to the final CR you end up with on your piston choice.How much would new pistons effect the choice of a cam?
Based on that in of I've changed up the selection a bit. In order I'm looking at the Lunati 10230702LK, the Summit SUM-K6401, Com Cams CL21-306-4, and Mopar Performance P4286677. I've also been hearing a lot about pistons. I had every intention of replacing them, but I guess that final decision will come once I actually get the motor apart and see what kind of condition they're in. How much would new pistons effect the choice of a cam?
All I know is that I'm no longer buying into all the b.s. hype and I'm simply going with a MP Purple camshaft on my next build.
Fwiw, I've been surfing CL looking for a MH 440 block to keep myself busy. Getting restless again...
(Sent using Forum Runner)
Yep. The one with the 452 heads that use the GM 5/8ths "peanut" plug.......
Thanks for all the help! How do I go about CC'ing my chambers? will this change at all with a port job on my heads? and am I going to need new valves or push rods?
