Furyus67
I recently had everything out of the engine bay, so prior to reinstalling the Master Cylinder I bench bled it with full piston travel, dumping the fluid back into the reservoirs.
Now I just tried to bleed the brakes on the car. The rears seem fine. When I got to the fronts, I topped off the fluid, had my wife mash the pedal (everything seemed fine) and then I loosened the bleeder to release the fluid. I tightened it back up and began repeating the process. Wife stated the pedal did not feel the same (she said no resistance), but I could also hear that the brakes themselves were not expanding. When releasing the bleeder the flow was not as strong, with a couple spits of air here and there. I then went and topped off the MC before it got dry. I tightened up the MC and went back to the wheel. Immediately after topping off the MC my wife began pumping the brakes and stated it felt good again and I could hear the brakes expanding. So I release the bleeder and got a nice strong flow of fluid. So we did it a second time and immediately after that good bleed, wife stated the pedal didn't feel good and I could hear the brakes were not expanding, we did this a few times and the pedal never felt good and the brakes didn't expand. So I go top off the MC again and immediately after topping off the MC the brakes felt good again.
This repeated multiple times on the front passenger, so I moved to the front driver. Same exact sequence of events.
It's almost like taking the top off the MC is letting the air out and making things better.
Any ideas?!
67 Fury
Manual brakes.
New brake lines all the way around.
New MC.
Any ideas?!
67 Fury
Manual brakes.
New MC.
