So - further to the saga with my AC vacuum switch and blower motor issues - I bought a cheap ampere gauge to measure the load and startup spike of the blower motor in my 66 T&C, since I was thinking that it was on its way out and drawing too much power, and had subsequently melted/overheated the electrical contacts in the blower motor switch and the vacuum switch.
I can't post a video here without putting it on YouTube first. Going through that rigamarole for a 3 second video is of no interest to me.
Suffice to say that the meter showed an instantaneous spike of nearly 40 amps when starting up, and then almost immediately things settle down to a steady 13 amps running the motor.
Here are two stills from the video:
STARTUP SPIKE 37.5 amps
RUNNING DRAW 13 amps
Initially I thought that excessive... even though the blower motor doesn't make any odd sounds, doesn't smell burnt, nothing.
So I tested my spare blower motor on the bench - with EXACTLY the same results.
So, now I think that possibly my first theory is not valid, and that the problem may lie elsewhere.
Thoughts?
FWIW, I have now sourced 3 of the correct AC Vacuum switches, and an additional used blower switch and have an NOS blower switch on the way. Thanks to @Mudeblue, @David Grippin, @Furyman and @Mike66Chryslers for helping me out. So my next steps are to gut the dash and find out where the real problem lies...
Thoughts?
