Lol
@Gerald Morris - you've obviously never dealt with pulling the switch on a 65 or 66 Chrysler - a totally different animal than a Dodge or Plymouth, or a 67 or 68 Chrysler for that matter... there's little to no room up in there. To even LOOK at the switch (which involves lying on your back with your head on the gas pedal and your feet over the seatback), the ash trays have to come out, AC and defrost tubes have to come out, steering column lower cover with fresh air vent cables and controls has to come out (which you then have to put under your head, which is uncomfortable to say the least), the AC vacuum switch, and its push buttons and tubes all have to come out ...and if one wants to actually pull the entire HVAC control unit, the radio should to come out, the speedo should come out for best access, it's a pain, believe me!
Regardless, I went through every single connection point in the chain, from fuse box to the blower motor.
Not a single piece of evidence of bad connections, overheating wiring, melting, nothing, nada. There were a couple of "loose" connections which I tightened up, but they were still OK by comparison to other connections. Blower motor resistor assembly was fine (I have an NOS one on standby, but it was OK), and yes, I can bypass all that to send a full unresisted 12V to the blower motor if I really need to...
Any connection I took apart I cleaned with emery cloth to ensure "new" metal to metal connection, and tightened up the female connectors.
I am now suspecting the blower motor - but why would it quit and come back, quit and come back? If it was going bad, wouldn't it just get worse and worse (slower) and just seize up and die?
Of course when I put it back together everything worked fine, and when I started the car (it's on jack stands to deal with the fuel leak issue) the temps dropped to meatlocker range in about 5 minutes of idling. The proof will be in the next time I drive it with the AC on for any length of time... so I don't know if I'll get to that before I head off to WPC next week, but I can send 12V directly to the blower if I need to.
I will report over the next couple of days. I am waiting on a fuel tank sending unit gasket.
