Bolt question
Marian
Leavenworth, Kansas
I've been doing some research about bolts. I noticed that alot of the hex bolts have a L and then an 8 stamped on them. There are 6 lines on the bolt as well. From what I learned this is a grade 8 bolt but what is the "L"? Is this the foundry? If so what foundry and where? Inquiring minds want to know. Or at least this mind, while having nothing else better to do until the games start.
Marian
[h=1]ASTM A320[/h]
Quick Links
[h=2]Scope[/h]Originally approved in 1948, the ASTM A320 specification covers alloy steel and stainless steel bolting materials for low temperature service. This standard covers rolled, forged, or strain hardened bars, bolts, screws, studs, and stud bolts used for pressure vessels, valves, flanges, and fittings. Like the ASTM A193 specification, unless otherwise specified, the 8UN thread series is specified on fastener larger than 1” in diameter.
Below is a basic summary of a few of the common grades within the ASTM A320 specification. A number of other less common grades of ASTM A320 exist, but not covered in the description below.
[h=2]Grades[/h]
L7 Alloy steelAISI 4140/4142 Quenched and tempered
L43 Alloy steelAISI 4340 Quenched and tempered
B8 Class 1 Stainless steelAISI 304, carbide solution treated
B8M Class 1 Stainless steelAISI 316, carbide solution treated
B8 Class 2 Stainless steelAISI 304, carbide solution treated, strain hardened
B8M Class 2 Stainless steelAISI 316, carbide solution treated, strain hardened
[h=2]Mechanical Properties[/h]
GradeSizeTensile,
ksi, min
Yield,
ksi, min
Charpy Impact
20-ft-lbf
@ temp
Elong,
%, min
RA, %, min
L7Up to 2[SUP]1[/SUP]/[SUB]2[/SUB]125105-150° F1650
L43Up to 4125105-150° F1650
B8
Class 1
All7530N/A3050
B8M
Class 1
All7530N/A3050
B8
Class 2
Up to [SUP]3[/SUP]/[SUB]4[/SUB]125100N/A1235
[SUP]7[/SUP]/[SUB]8[/SUB] - 111580N/A1535
1[SUP]1[/SUP]/[SUB]8[/SUB] - 1[SUP]1[/SUP]/[SUB]4[/SUB]10565N/A2035
1[SUP]3[/SUP]/[SUB]8[/SUB] - 1[SUP]1[/SUP]/[SUB]2[/SUB]10050N/A2845
B8M
Class 2
Up to [SUP]3[/SUP]/[SUB]4[/SUB]11095N/A1545
[SUP]7[/SUP]/[SUB]8[/SUB] - 110080N/A2045
1[SUP]1[/SUP]/[SUB]8[/SUB] - 1[SUP]1[/SUP]/[SUB]4[/SUB]9565N/A2545
1[SUP]3[/SUP]/[SUB]8[/SUB] - 1[SUP]1[/SUP]/[SUB]2[/SUB]9050N/A3045
[h=2]Chemical Properties[/h]
[h=1]Bolt Grade Markings and Strength Chart[/h]
Head MarkingGrade and
Material
Nominal Size Range
(inches)
Proof Load
(psi)
Min. Yield Strength
(psi)
Min. Tensile Strength
(psi)
[h=2]US Bolts[/h]
No Markings
[h=3]Grade 2[/h]Low or medium carbon steel
1/4 thru 3/455,00057,00074,000
Over 3/4 thru 1-1/233,00036,00060,000
3 Radial Lines
[h=3]Grade 5[/h]Medium Carbon Steel, Quenched and Tempered
1/4 thru 185,00092,000120,000
Over 1 thru 1-1/274,00081,000105,000
6 Radial Lines
[h=3]Grade 8[/h]Medium Carbon Alloy Steel, Quenched and Tempered
1/4 thru 1-1/2120,000130,000150,000
Stainless markings vary. Most stainless is non-magnetic[h=3]18-8 Stainless[/h]Steel alloy with 17-19% Chromium and 8-13% Nickel
1/4 thru 5/8 40,000 Min. 80,000 – 90,000 Typical100,000 – 125,000 Typical
3/4 thru 1 40,000 Min. 45,000 – 70,000 Typical100,000 Typical
Above 1 80,000 – 90,000 Typical
Head MarkingClass and
Material
Nominal Size Range
(mm)
Proof Load
(MPa)
Min. Yield Strength
(MPa)
(MPa)
[h=2]Metric bolts[/h]
8.8
[h=3]Class 8.8[/h]Medium Carbon Steel, Quenched and Tempered
All Sizes below 16mm580640
800
16mm - 72mm600660830
10.9
[h=3]Class 10.9[/h]Alloy Steel, Quenched and Tempered
5mm - 100mm830940
1040
12.9
[h=3]Class 12.9[/h]Alloy Steel, Quenched and Tempered
1.6mm - 100mm9701100
1220
Stainless markings vary. Most stainless is non-magnetic.
Usually stamped A-2
[h=3]A-2 Stainless[/h]Steel alloy with 17- 19% Chromium and 8-13% Nickel
All Sizes thru 20mm 210 Min.
450 Typical
500 Min.
700 Typical
Tensile Strength: The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Yield Strength: The load at which a material exhibits a specific permanent deformation.
Proof Load: An axial tensile load which the product must withstand without evidence of any permanent set.
1MPa = 1N/mm[SUP]2[/SUP] = 145 pounds/inch[SUP]2[/SUP]
No idea why I have to look in such a list. :)
If you search with capital L you get 30 listings, but L 8 does not exist. It seems if a company was closed and by that did not renew their sign they're not included in there.
I'm sure that list does not include all the bolt manufacturers. Looks to me it's a list of marking from approved vendors for the government. The L 8 may be there.... It may not.
It may not exist anymore either. A lot of manufacturers have been bought or closed over the past few years... or they changed their logo if they started manufacturing overseas. Anything is possible.
IMHO, the thing is to buy the bolts from a good source. In other words, go to a good bolt store rather than Home Depot or Lowes.
