Calling all ‘68 owners, tire pressure decal pics please
HWYCRZR
Fargo, ND
As posted in another thread, I am looking for original examples of the tire pressure decal. As far as I can tell they changed frequently and may have been year specific. In some examples on B bodies they varied between early production and later production.
My ‘68 Polara was built in August ‘67 and has tire code 53 on the broadcast sheet (8.25x14). Belvidere Plant. I can’t seem to find a source, but also don’t know what the original should look like.
Here is the one from my 68 Fury. Build date was April 22, 1968
Code on the build sheet is 53. I have a friend has a 68 Newport. If I remember next time I see him, I will get a picture.
Thanks for the information.
This picture blows my recent learnings out of the water. Supposedly the tire code on the broadcast sheet (53) is supposed to match the last two numbers on the decal? My source below. Of course no other C-bodies to reference on their site.
Also said it could be different between plants.
Tire Pressure Instructions Decals Mopar Dodge Plymouth
Probably different between the plants as with other things. Someone like a Bill Watson would likely know.
How's the car coming along?
I should finish my seats this weekend. I have half a NOS exhaust system, I need to get someone out to install my windshield. I can see daylight.
:thumbsup: Well done, hope you're soon cruising the highways, like Easy Rider, get your motor running, head out on the highway.
Brilliant job you've done all round.
Base tire for the base Newports w/o a/c would be 8.25x14. A/C Newports should have been 8.55x14 tires. A/C PDB cars would be 8.45x15, non-a/c cars would be 8.15x15. Chrysler wagons could go up to 8.85x14, I believe, as the '65s were 9.00x14.
Info for Polara/Monaco is a bit different, as the Plymouth information probably is, too. Info from the FSM, via www.mymopar.com
Hope this helps,
Hope this helps,
The issue is every tire option seems to have its own decal. I have the charts from the service manual and operation manual which don’t do much good in helping find the right decal.
My desire is a picture of the tire pressure decal the was put on early ‘68 Polaras equipped with tire code 53 which was the 8.25x14 tire that came out of the Belvidere plant with no trailer package or A/C
Please keep all 68 C-body tire pressure decal pictures coming for documentation.
Please provide decal and fender tag picture.
If no fender tag picture then include the following with the decal picture:
Model / trim level
Tire code if known ( on bottom line of fender tag)
A/C or non A/C
Let’s see how many different ‘68 tire pressure decals we can come up with.
Thank you
When these tire size/pressure labels first came out, the orientation was that the owner could look at it and use as a guide in purchasing/maintaining new tires for the vehicle. A consumer protection issue.
In that orientation, ALL of the available tire sizes would not need to be listed, just the smallest standard size on that platform of vehicle (to support the weight of the vehicle with good reliability and durability). Station wagons and their different tire capacity needs might have a decal specific to them?
The pressure listed would be more "middle of the road generic" than more model specific, which is in the owner's manual.
Back then, there were usually THREE tire pressure recommendations. The "stock, smooth ride/standard load" orientation usually was for 24psi. The "normal load/use" was a few psi more (as the "26psi" listed on many). THEN, there was the "max loading" psi listing, for the "full rated load" of the vehicle, 6 passengers and luggage. Additionally, IF speeds of over 70mph were to be used, to increase the psi by "4psi", but to not exceed the 32psi max pressure for 4-ply rated tires. All of this was in the FSM and Owners Manual. In the case of "Extra Load" (6 ply-rated) tires on some specific station wagon models (usually B-bodies?), then 36psi would be the max pressure.
Station wagons, usually were spec'd with a somewhat low front tire pressure and increased rear tire pressure, compared to the sedans/hardtops/convertibles.
End result is that starting with the basic 24psi pressure, if you drove on the freeways, you bumped it up to 28psi, per recommendations. For "max load", a bit more.
As a side note, in the pre-PMetric tire size days . . . I used that 24+4 orientation on our '66 Newport, for the rear tires. Then my calculations determined that for the front tires to proportionally carry the same relative tire load, I put +2psi past that in the front tires. This way, each axle/tire would support the same proportional amount of weight. This is the exact opposite of the factory-spec f/r pressure bias. But, handling became a bit crisper and front tire wear decreased as rear tire wear was "flat" rather than wearing more in the middle (from too-high inflation pressure). And that's what I started to run everything at, in that same orientation. The later fwd cars or some shorter-wheelbase "pony" cars might need 4psi (more than the rear tire pressure) to balance out their 60% frontal weight bias. NOT related to the factory recommendations, just my own experiences. Proceed at your own risk.
The higher pressures, tended to make the tire tread patch more "firm" and decreased flex as the tire rolled down the road. Keeping all tread ribs open rathe than otherwise, in all driving conditions. Much moreso with bias ply and bias-belted tires, than with radials.
Just wanted to mention these things to help with clarity on the tire pressure issues.
Still looking for any tire pressure decal examples for ‘68 c-bodies with the 8.25x14 tires. Or a source if one exists.
My 68 Sport Fury has a build date of April 30th and came from the factory (St. Louis) with 14" Magnum 500s all around and here is a picture of the tire pressure decal.
Thank you MoparJim, That is the closest I have seen that is most likely relevant to my car as 8.25 -14 were standard. Now the next step is to see one ( if it exists) with the 8.55 - 14 tires on it which were included with the towing package, and standard on wagons. I am curious if that was a special decal dedicated to those tires, or if the decal showed 8.25 and 8.55-14 tires.
I have now seen Chrysler and Plymouth examples. No Dodge examples yet.
@live4theking could I ask what tire code is on your fender tag, manufacturing plant, and production date? Or just a picture of your fender tag would suffice.
This format looks very close to what is in the Service manual and Owners manual.
Thank you
@Dodgedon
Your ‘68 Polara wouldn’t happen to have an intact tire pressure decal you could take a picture of? If so a picture of the fender tag as well.
Thanks
