polara71
Still a tough crowd around here. ;)
Always will be a rough room, we can take it
Frams are good for the 500 mile break-in to grab all the leftover shrapnel.A Fram filter .....? We are different .............
The needle stays right above the low mark thanks to the perfectly working 185° Stant SuperStat™ thermostat......How effective is the new radiator? Where's the needle on the gauge now after warm up? Same place or lower?
At the 500 mile oil change, in goes the WIX.
So then you are saying it wasn't the thermostat????????? :urkidding::urkidding:
I know more about o-rings than you know about head gaskets. Ouch! Too soon?
So, ignore the possibility that the thermostat is not opening and just start pulling the heads.
I broke two cardinal rules. I deserved getting bit on the ***.
1. Read ALL the specifications including the fine print. Just because you're in a rush, you cannot assume anything.
2. Compare the original part to the new part when you get it. Just because you're in a rush, you cannot assume anything.
You forgot rule #3: If it's not a long time trusted name in auto parts assume it's improperly made.
HaHa, this thread came up as a suggestion on another thread. I was almost certain it was the thermostat.
