coach2ma
Hi, folks.
Does it sound possible that headers that pass extremely close to a tranny pan could possibly ruin the gasket and cause leaks via heat damage? There is little clearance (perhaps an 1/8th of an inch at best) between the header and the front left corner of my tranny pan (front left if you are facing the car) and that is exactly where my tranny fluid is leaking out of my pan. The car drove fine with no tranny leaks for about the first 3 weeks of short usage after install of the headers (an hour or two of light driving each time in Northeast spring temps). But after one long cruise that lasted all day and was more than 100 miles of driving, the next time I went to the car after parking it that day there was a puddle of ATF4 under it. Since then, it pushes out better than half of what I re-add during each drive (about 3 short drives since). I checked the tightness of the pan bolts, and while they did need a little tightening, they weren't particularly loose. After tightening, I re-added fluid, but it made little difference and the leak appeared in the same spot on the pan, almost immediately. I assume the gasket must be compromised (though it was not old)....could it be the heat proximity? Change the gasket and get some (really thin) heat shielding to try and wrap the header in that area, perhaps?
