hm. Here is something... when i turn the key, there is some load on the battery, approximately... 30amps. I see 11.7volts (should be dead right?), it cranks over strong and when cranking I see 10.5 - 10.8v. While running, I see somwhere 13.8 to 14.5v, my fan kicks on and the charging system dips as low as 12v....then slowly climbs to about a steady 12.5v at an idle. I am trying to figure out another idle "issue" with my efi (wont idle higher than 800 in drive). I know my voltage goes into the 13v range at 900rpm, so maybe i just need a smaller pulley on my alternator?
EDIT: I am mainly trying to figure out if there is even an issue.... thats why i was asking how the system works.
