- Joined
- Nov 14, 2010
- Messages
- 28,251
- Reaction score
- 27,619
![LOL :lol: :lol:](https://www.forcbodiesonly.com/mopar-forum/styles/default/xenforo/smilies/smiley-face-laughing.gif)
LOL - Well, I bought the car, so I guess I get to find out how much fun / frustration can be found in a 1961 Chrysler.
The biggest difference between 61 and 62 Chryslers is that in 61 the cast iron Torqueflite trans was in use, while in 62 a change was made to use the new aluminum case Torqueflite. 61 engines have a different crankshaft than 62 engines because of the different way they connect up to the two different transmissions. If you have a 62 engine, whoever did the transplant may have also put an aluminum transmission from 62 in along with it, otherwise they would have had to change the crankshaft to properly mount up to a cast iron trans.Hello folks -
I've owned dozens of classic cars over the decades, but never a Chrysler, or any Mopar of any flavor. Its a long story as to why, but I am considering a 1961 Newport, and it has a 1962 413 engine with cross-ram intake, dual carburetors...and....I have no idea what I'm even looking at, except the it looks kinda cool ;-). I have a few questions, and hop you can educate me:
1) Someone has suggested to me that this engine, with 10:1 compression, will not run well on pump gas. I know that the street-manners of a car and its tolerance for pump gas depends on more than just the engine numbers - and even if it HAD 10:1 compression, I assume that was back in 1962......might have changed a bit since then. but still, I have no interest in finding the needle in the haystack gas station with exotic gas - 92 octane is available everywhere here, and that's what I run in everything I have - from a 2024 Subaru to a '68 455, to a 62 Jaguar XK. Does the cross-ram 413 really needs something special, or can I run 92 octane pump gas?
2) I have experience tuning dual carbs - its....erm... annoying...and usually I'm working on a British SU carb, like the Jaguars. That said, its nice when everything is synchronized... what sort of trouble / issues etc can I expect with the cross-ram set-up? The carbs are newer edlebrock, and I am familiar with them, just not two of them on some crazy manifold ;-) . I don't mind tinkering, but I really don't want to ge wrapped up in a carb sync nightmare that never runs properly.
3) Is there anything you think an innocent Chevy guy ought to know about a '62 413 before deciding to own one? I've worked on classic Chevys, Fords, Mercedes, Jaguar and even briefly a Buick nailhead, but I've never turned a wrench on a Chrysler.
Thanks all - appreciated.
I think it has the '62 transmission. From what I can see of the transmission, it looks like an aluminum case, and I'm 96% sure the engine is 1962, so that would be the obvious solution.The biggest difference between 61 and 62 Chryslers is that in 61 the cast iron Torqueflite trans was in use, while in 62 a change was made to use the new aluminum case Torqueflite. 61 engines have a different crankshaft than 62 engines because of the different way they connect up to the two different transmissions. If you have a 62 engine, whoever did the transplant may have also put an aluminum transmission from 62 in along with it, otherwise they would have had to change the crankshaft to properly mount up to a cast iron trans.
I thought perhaps I'd just buy a case of octane booster and run a bottle with every fill up. Supposed to boost the octane 4 points, so that would give me 96 octane.Lads --
I
- I run the highest octane unleaded but with every fillup I also add about five gallons of 110 octane leaded racing fuel ($8.99 per gal. last month) to the tank. The engine will survive on lower octane gas, but the plugs tend to foul very easily with it.
Can you remember which MOPAR electronic unit you used? My go-to is normally Pertronix, but I'd use a MOPAR unit if there's one out there that is easy to install and works well.- That dual point distributer was and is a weak point. I replaced the one in my current ram car with a later transistorized MOPAR ignition and put the old job in a box in my garage.
There are "Mopar" type units out there, but they really are offshore built units with questionable dependability.Can you remember which MOPAR electronic unit you used? My go-to is normally Pertronix, but I'd use a MOPAR unit if there's one out there that is easy to install and works well.
John --Along came Mancini and others who had a market for parts like this and long story short, they started importing the parts for a kit. In fact, many of the ECUs aren't even built like the original part, we've even seen some with the GM HEI module in them... and now it's come down to the transistor on the outside heatsink is a fake, just so it looks like the original Chrysler part. Their offshore distributors seem OK, but I don't think they are as good a quality as the OEM.
So, while there's been guys that have bought these new kits and not had a problem, there are more failures than there should be and if nothing else, you aren't getting what you think you are.
So, you have a couple choices besides the offshore built kit. One choice is to buy a rebuilt OEM Mopar distributor from @halifaxhops and use a GM HEI module. Personally, I feel that's about the best performer. . You could also pair that distributor with an offshore ECU and just carry a spare ECU.
You could also could keep the dual point.... Honestly, I've run them in different cars now for a lot of miles and they are a really good distributor. The main issue is you can't buy a new condenser that is reliable. Some don't work right out of the box. That means finding NOS USA made condensers (again, @halifaxhops is your go-to).
When all is said and done, the Pertronix with that robust dual point distributor is a really good option. I like the Pertronix Ignitor II myself. That will let you eliminate the ballast resistor and you can run a hotter coil.
Yea - thanks for that. I am learning steadily - this engine is a 413 (or at least reported as such) and I'm told comes from a similar era New Yorker. I've been speculating its a '62 base don a few small clues, but once the cat gets here I'll try find the various numbers and we'll find out for sure.Since you're just into the MOPAR scene, I don't know if you're aware that the corporation had a number of wedge engines, which to a great extent have interchangeable parts. However, there are basically two different wedge blocks: the B Series (350, 361, 383, and 400) and the RB Series (primarily the 413, 426, and 440, although there was a RB 383 in '59-'60 used for Windsors and Saratogas). Chrysler wanted a taller block for the longer stroke of the 413 and its brothers, so I just want to make sure you don't get something intended solely for a B block and which won't fit a RB.
Joe
I may try keep the points, but my gut tells me I'll go electronic. I typically use Pertronix in everything - sometimes just the small under cap unit, and others the whole distributor, if they offer one. I'll see if I can find the Pertronix part number.You could also could keep the dual point.... Honestly, I've run them in different cars now for a lot of miles and they are a really good distributor. The main issue is you can't buy a new condenser that is reliable. Some don't work right out of the box. That means finding NOS USA made condensers (again, @halifaxhops is your go-to).
That leaded-gas thing isn't a hard/fast rule.A 1962 413 that is stock requires leaded gas. To burn unleaded gas, do a valve job and install hardened exhaust valve seats. The stock valves are already hardened. vacuum diaphram to eliminate any pinging.
Fury Fan --That leaded-gas thing isn't a hard/fast rule.
It depends on how the car is driven, and it doesn't happen immediately.
High speed/rpm, towing, and racing cause more damage.
I daily-drove a 68 318 for about 7 years, mostly highway use at 75mph (I read this qualifies as 'hard usage' regarding unhardened seats).
I used 1 gal of 100 low-lead in each tankful for a few years, but I decided to stop because it was a hassle.
I took that 318 from 110k to 180k before I pulled it for running rough.
The heat crossover passages plugged on it twice, and that might've been happening for a 3rd time when I pulled the engine out (I did not do any diagnosis on it).
Were the exh valve seats receeding? Who knows.
My point is - mine survived for a lot of miles.
If you're not going to drive your car hard or for a lot of miles, don't feel obligated to do the lead or hardened seats simply because 'that's what they say'.
Fury Fan --
True, but why have ram tubes and two big 4-barrels if you don't flog it? My idea of "hard usage" in town is foot to the floor, screaming tires, howling unsilenced air cleaners, roaring exhausts, and billowing smoke while blowing away some "tuner" in a pacific rim SEE-dan with a souped lawnmower engine who thinks he has an automobile. My "hard usage" on the highway is pegging the speedometer -- easy with the 120 mph instruments on my '60 Fury and '65 SF, but close to impossible on the 160 mph unit on my Vette and the 150 job on the C. However, I did get the C's needle to nudge the 150 mark, but it was on a slight downgrade; I did likewise with the Vette on the same stretch of I-25 (south of Colorado Springs). Of course, both are old speedos, so I probably got (maybe) an honest 140-145 out of each. But it sure was fun scaring the hell out of some flatland "touristers." And once, while working the gears on my Vette, I did 106 while in still in third -- at least that's what the officer said I was doing.
As for highway driving at 75 here in Colorado, you're obstructing traffic.
Joe
Just drive the damn thing.
Talk, talk, talk.
Drive it and adapt. It's a car, and your not setting out on a round the world voyage.
My Charger has a wrong sized piston in it. '66 block, '70 rotating assembly, as mentioned wrong size 80s replacement piston, 1976 #452 casting heads, a 318 pickup truck transmission and a welded cross pin rear end.
I put 16k miles on the car, ran power tour last year, would leave tomorrow for the West coast. These cars are very durable, just drive it.
Fury Fan --Are you sure it's not an AMC?
