caps
This may have been asked before, Are the center caps repairable? Possible to take out the pitting and re chromed?
hope so..got two sets of gear type caps with different states of wear which will need to be rechromed..worst case will sand and prep similar to a car and use silver chrome paint
I had more caps in a cabinet that I located after I put all that away. Bottom line is, what do I need with all that stuff, so it had to go...
Need a solution to the caps' biggest problem: A repair to the rusted out retainer clip ring.
Posted via Topify on Android
Use a dremel to drill out the rivets and then use small self tapping screws- works better than new. I've been doing this for years when piecing together road wheel sets.
Thank you Mr C. I have already been doing that. What I was referring to is when there are enough prongs on the rings damaged to make the ring itself useless.
