Thanks Dave so what are you saying, stock manifolds crack or modified crack or they both crack?
They are more likely to crack if modified, but on a large displacement build they will probably crack either way.
I'm not dipping my toe in that hot water again. All these guys want to run 800 HP through exhaust manifold because they look correct, and headers are only for race cars, and I'm not going to rev my 800 hp engine over 4200 rpm, and so on. They have more excuses to run the manifolds than you can possibly argue against, nope I'm done.
Thanks Dave for clarifying.
Those are some well scienced cars. I thought about aiming my Challenger for the pure stock series but I don't think I have that much patience.Those FAST guys are amazing.
One of the members here has a Fury in a series like that, can't remember who.
Obviously that means exhaust manifolds are a hinderance, but to be honest - exhaust manifolds can be dealt with by camshaft design, in order to minimize their "negatives" to power.
They are going to crack either way, it's inherent in their design. Mine were on a bone stock 440 and they cracked.
Hey I understand your frustration with us exhaust manifold weirdos lol. If I could do a back to back on exhaust manifolds and headers I'm sure my buttometer would pick the headers for sure and my Depends would verify it. Headers [nice ones cost some dough] is rather major expense plus the exhaust work involved. So my plan is this since I have extorted only so much to build my engine. Gonna build the bottom end right as well as good heads and an attempt at a good cam [maybe roller]. Tidy up the stock intake and exhaust manifolds and slap on a bigger carb. I may even opt for a wide band exhaust sensor [maybe stereo,one on each pipe] so I can tune it well.. If happy I am done,if not I can easily go to a better intake and or headers later. What ya think 70bigblockdodge?
Were your stock logs or HP's ?? So it is correct to assume any cast iron exhaust manifolds ,stock type or HP manifolds will crack?
Let me just highlight this part again: "Headers [nice ones cost some dough] is rather major expense plus the exhaust work involved."
Yes. A set of TTI headers, if you get them coated, and figure other associated costs are $1000 or close to it.
This is the "marginal $1000" that I've talked about elsewhere, and it's totally maddening to figure out!
If you're building an engine, and you're determined to do it nicely, but not extravagantly, there are certain things you're going to do: pistons, pins, rings, bearings. Probably some rod/machine work to make sure its nice. Bore your engine, probably. Rebuild your heads with hardened seats, new valves, springs, etc. Machine work. New quality cam and lifters. Dual exhaust. Maybe HP manifolds (if you can get them inexpensively, like I did).
I've decided that 440-Source heads are better than stock, and not much more than getting a good head rebuild, that I'm going to add those in.
So that's my baseline. A hydraulic cam is a hydraulic cam, cost-wise. There are some additional costs to non-stock, but not much. So cam selection is a place where you can make another difference without spending a bunch of money.
But what if you want to have a bit more? That's the "marginal $1000." For about $1000, you can have one of the following: Headers ($800 or so), Roller cam ($1000 or so), stroker kit ($1500 or so). Again, these aren't the prices of these items, these are the costs over choosing a more stock-like option.
Which of those three is the best bet? I just don't know, and it's why I keep driving all of you guys crazy talking about it. I don't have unlimited funds to make my dream engine, but I do have about a thousand bucks over a good quality rebuild to make more power. What would make better power in my idle-5000 RPM range, a 440 with good flat-tappet with headers? Roller , 440, with manifolds? Flat-tappet, manifolds, 505"?
They're all pretty similar in cost, and I don't know how to figure which one is better in the real world for that cost.
All the research I've done on stroker motors says to spend the money on the bottom end, if your not redlining it stock rockers with flat tappet cam should do the job.
