jcslocum
I have a cone type Sure Grip (3.23 ratio) apart to look it over before installing into my '66 Fury III. All parts look good and the cones have not bottomed out in the case. I measured the clearance (with hard wax) between cone face and bottom of the case and have right about 0.040" thousandths of an inch clearance. I have read every thread I can find on refurbishing this unit and come up with some different facts that have been posted.
My cones look like this:
This one from a trusted member:
I'm rustyratrod from FABO. Take some modeling clay and put a piece about the size of a marble into the case half end where the cone fits into the case. Put a little grease on the face of the cone to keep the clay from sticking to it. Now install the cone into the case and press it in as far as it will go. Remove the cone and measure the thickness of the clay. I recommend machining the cone end if clearance is less than about .060". When the face of the cone hits the inside of the case, the unit becomes ineffective.
So, my cones are under this 0.060" limit recommended by Rusty. I have seen another post where the clearance when disassembled was 0.087"
I used Play-doh because that's what I had and it looks like I'm good! I have 2,2mm (0.087") clearance on both case halves.
What I'm understanding is that at 0.040 clearance the cones are worn, what looks to be 50% (if I take the 0.087" as new) and that it will work, but not optimally with the lower spring force due to wear. This is not a DD or drag car, It's a Fury wagon that I bomb around in. I wanted a better ratio from the 2.73 that's in there right now as well as posi. My refurb thoughts are as follows:
- Leave the cones alone and shim the springs for better operation
- Machine the face the cones to get "like new" clearance and shim the springs
- Leave it alone and use as is
