Copper foil tape: a good fix for aged circuit boards!
Gerald Morris
Tucson
Greetings C-body Moparians! This evening I rejoice in having found the failure point in the turn signal circuit on Gertrude, our 1968 Newport ragtop. I had surmised late last year that the long summer heat had damaged the new Shee-Mar turn signal switch I had replaced the original with just 2 years prior, having found a small bit of metal loose in the steering column nearby. Alas, my flawless, trouble-free replacement of the SM-107 this time didn't restore the right turn signal! Having already checked the indicator bulb and circuit board with a cursory visual inspection, I broke out both of my test lamps, my favorite voltohmeter, a couple test jumpers and a fresh pack of Lucky's to find the Trouble.
P 8-93, 1968 Chrysler Service Manual
I tested for the pulse DC at pin 9 on the Instrument Lamps Connector and found it good. Since my test lamps also retain the venerable Edison resistance, my flasher (which putatively shouldn't DEPEND on such!) responded well, and I knew that the problem was in the wiring or circuit board above the main instrument panel: the one showing from left to right the left turn signal indicator, the cold engine lamp, the hot engine lamp, the high beam indicator in the middle, directly above the steering column, the low oil pressure warning lamp and finally, the right turn signal indicator. Since the circuitboards are conveniently split with the right board having only the turn signal and oil pressure indicators, I was able to isolate the problem in short order. I plugged the 10 pin connector back in, then tested the 3 pin plug meant for the right board. Again, I had good voltage there, but, no turn signal indication, and no blinking anywhere in the LEDs I use front and rear...
So, I checked the bulb, which dimly lit. I checked another such from the spare instrument panel I got with this car, and inspected THAT board. Turns out it's also compromised, so I bega repairing the conductive runners o the original (to this car) board. I ran a strip of foil from the grounded lug to the ground side of the bulb, checked with that, to no avail, then ran another strip over the old conductor to the hot side, ot eglecting to wrap some of the copper foil around the connecting post which plugs into the 3 conductor plug. I replaced the dim bulb with a fresher one from the other panel, and FINALLY....FIAT LUX!
First, restore the ground...
Then the hot side, all the way to the plug-pin, to the tan wire on the left end of the plug as shown here.
So, for a fraction of a cent's worth of copper foil, I've restored the right turn signal to full functionality in our family car! Mind you, it took about a day's trouble shooting and careful, tedious work to arrive at this solution, so I thought some of you might spare yourselves some trouble with this or similar problems, which I know plague a number of you.
I hope in another year or 18 months to be able to more systematically dress and clean up my spare boards, restoring them and testing them at leisure instead of under the duress of necessity. I saw some mistakes I had made in installing that Shee-Mar switch the first time, which I avoided happily this time, so I expect no trouble from that element again for some decades... I'm amazed at how forgiving these simple, rugged old systems are!
Source of the copper foil and how to keep it from tarnishing?
GREAT fix!
I'm not sure that the back side of the copper tape will make good electrical contact with the trace on the board. The sticky layer will interfere. I don't think that copper tape was intended for that sort of use.
Read the advert on this: https://www.amazon.com/Conductive-Adhesive-Shielding-Connections-Grounding/dp/B0CND1YTKQ/ref=sr_1_3_sspa?crid=2MQRB9HN8CXU3&dib=eyJ2IjoiMSJ9.-L6lrWVv5nWnYg3dIvol7E9CEkJPAHzKjdHoNk_VmWqKn2o6-ybFeTAAgQj_JCxPFgwJXtxmyCY9WMpuMGWxsl_G8cfOe5zlg9dI8DXA0nQcoT_NqrkAmlcSGgGG9ksuj4WPrpIwffxjaooEvz0rHIr39PMj4LT8P-HM_PjU6LCtucTTMMI5jnUAtJLC1D9Xz7vFbnie-oPaZ0vD1hBDb3OTzUAaOzI_wZ7B1SQqO-3e3j6L_v6wMSZHoBdCmfTg9n7mO8K9IdSnNWypZ0SKRfLxjZI6NDTwjqPj1iGh1As.upJEei9uzxoEKsTlstQv-eDdbaVU_Eisp2W7AorCAhA&dib_tag=se&keywords=copper+foil+tape+for+stained+glass&qid=1737475521&sprefix=copper+foil,aps,169&sr=8-3-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
This tape is meant SPECIFICALLY FOR ELECTRICAL REPAIRS, and works well. I've used it on a Sony 9V bakelite "transistor radio" and a G.E. clock radio, both of these older than the 1968 Newport I used it on. At $9.99/66', or $0.0126/inch, the stuff certainly is preferable to the following:
which comes to $47.19 for folks in the continental U.$. for the nice looking new knockoff boards shown. I prefer to take an old board and dunk it in CuSO4, throw a little DC current in that bath and recoat the old surface, IFF the old epoxy board doesn't come apart in solution. It might well do so though, old glue being what it is.
Stained glass artists use generic copper tape to bind their bits together, with plenty solder. I used THAT stuff in the late 1970s to fix old radios and TVs then. The glue didn't much resist current on those juvenile efforts then either, though that tape wasn't explicitly MADE for electrical repairs.
GREAT fix!
Here's a TinyURL link, given the length of the original one, I reckon folks will prefer this: https://tinyurl.com/3ntmr9vb
The stuff oxidizes at the same rate any other copper surface will. Given how the original epoxy boards just got a few microns of copper surfacing, the tape offers an order or 2 of magnitude greater thickness. I got hip to using copper foil after borrowing a reel from my Aunty Karen's stained glass studio in 1979. I'd been fixing old electrical/electronic devices since I was 8 yrs old by then, with a true savant's gift for such work. I learned Ohm's Law around age 11 or 12 I recall.....
I can't get past the fact that current will flow thru the adhesive. I wish I knew of this stuff when I was in the elevator industry. We has traces burn off printed circuit boards many times. We would solder bell wire to make the repair on the damaged copper trace.
Adhesives can easily be compounded with conductive impurities. I too have stripped wire and soldered that onto a high current circuit board. The foil works better. Remember, even the general purpose stuff meant for stained glass had to bond well with lead solder AND the glass. Nokorode flux serves as another example of an apparently non conductive, non-polar substance which, by mixture with conductive impurities, permits solder to flow and bond with copper. The other thing to bear in mind is that electrical conductance is a surface phenomenon generally. For most folks, charge physics isn't intuitive. I simply got lucky by having a cool aunt and a knack for electrical circuitry.
