Crabby old Newport
Timsnewporttwin
Lee, MA
Hey Folks,
I asked a couple weeks ago about my 65 Newport. It was at my friends body for about a month. He was having a lot of trouble starting it.
Got the car back and it does have something wrong with it. Hard cold starting, once running it's OK. However now it has a popping type noise when driving, car lags a moment and picks back up. Seems worse in traffic and under a load like climbing a hill. Car does have power and accelerates ok after the popping.
2 barrell Bendix Stromberg carb. Rebuilt a couple years ago, new choke pull of and choke thermostat.
Anyone have a clue ? So far I've been told to take a run down the freeway, maybe bad coil, bad plugs (both have been changed). What might it's trouble be ?
Thank you for reading !
Tim
Sounds like water, or moisture in the fuel, or condensation under distributor cap
Hey Folks,
Tim
Sounds like gas igniting in the carb. If you take the air cleaner off do you see a flame? A bad intake valve will do this. A cracked distributor cap or two crossed plug wires, the vacuum advance not operating (bad v.a. diaphragm, line disconnected from under carb or intake manifold or vacuum port filled with carbon deposits) I seem to remember that the last two cylinders on the driver side could be crossed and you might not notice until you accelerated. But, I’d look for burn marks or cracks inside the cap first. I once floated a lifter that resulted in a bent push rod on a 72 Plymouth with a 400 cid being stupid and overrevving. It also popped. But it was an easy fix. Pulled valve cover and replaced the lifter and push rod without loosening anything. But, I did need a special tool to retrieve the lifter.
ps. sorry for the confusion. Somehow I inadvertently posted this inside timesportin post
Hey Folks,
Tim
A couple things jump out at me. First is how old the gas? Second, did you change the plugs after getting it out of the body shop?
What ignition do you have?
One time I got a partial tank of flaky gas. Had to use the accel pedal to keep it idling at a stop light. Got worse. Exhaust had a hollow sound to it. After I figured out what it was, I just drove enough to get the flaky gas used and a new batch in the tank. End of issue.
There are some fuel additives which will make the moisture in the fuel easier to burn, which includes alcohol as their main ingredient.
Download a FSM at www.mymopar.com (if you have not already done so) and get into the Carburetor section on the Stromberg WWC 2bbl carb. Check the choke adjustments! (initial closing via the thermostat and also how far the choke pull-off pulls it open as it starts).
Past that, the base initial ign timing and hot base idle speed. Then the fuel additive, fresher fuel, and put it on the highway for at least 50 miles. More can be better, though. Hopefully, it will get better the more it is driven and new fuel replaces the old.
It is very easy to cross #5 and #7 plug wires. When that happens, off-idle power will take a BIG dump, no matter how much throttle is applied. A customer had a '78 Newport 400 2bbl that his customer's grandson had put new plug wires on. Then it would idle pretty good, but had no power otherwise. I went over to drive it and discovered that it would not even chirp the tires! It was extremely doggy UNTIL the TQuad's secondaries could open and THEN it took off like an afterburner had been ignited. When he checked the wires further, the two rear driver's side wires had been crossed. When corrected, then it acted like it should. As they fire consequtively, no real "miss" was felt, just "no pawer".
"Back-fires" or "spit-backs" are usually ignition timing related. Might also be, possibly, a flaky timing chain sprocket. Timing chain ever been replaced?
Might just be a "build stack" of several contributing factors. First is to make sure the gas in the tank is fresher than it now is, checking the carb operation, tuning issues (to make sure they are where they need to be), before getting more excited about other possibilities.
Many thanks everyone ! I pulled a couple plugs, really fouled out. Going to get new ones and possibly change the coil. The motor has not been rebuilt. Unknown miles but original to the car. Doesn't use oil, runs well considering it was a junkyard escapee. Gas reasonably fresh
Also, the ignition is original, points, etc. Did check cap looked decent. Don't think it's crossed plug wires, car was fine until recently. Carb rebuilt by a specialist, I'd recommend to anyone. Hoping it's just the plugs. I do drive it easy and it tends to get around town type of drives. So that said I'll get it on the freeway for a good run after the new plugs. Good idea ??
Plugs don't foul on their own. Why did they foul?
Are they covered with black soot, indicating engine running rich?
Are the covered with oil, indicating oil leaking by the valves or piston rings?
If the car was running OK after the carb rebuild, I would look at the ignition.
You said, you looked at the distributor cap, what about the points and condenser?
Are the points burnt?
Is point gap correct when tested with a feeler gauge?
How old is condenser?
If there is any doubt about performance of points and condenser, I would replace both and properly set point gap.
If you don't do anything but replace the spark plugs, I think you will end up fouling the new spark plugs and not discovering your problem.
I'll bet that moving it around in the body shop fouled the plugs. Start and move/start and move/start and move... If they were doing that everyday like a lot of shops do, it can foul plugs.
Seems I've opened a can of worms here. I will take closer look at the points, condenser. It's been a while since these where changed but I haven't put a lot of miles on it. Timing chain sounds scary, as I know the motor is original, untouched. But listening at the tail pipe it sounds fine, like it always has. No skipping or uneven rumble from exhaust. I wonder if my tendency to baby it and being moved around the shop led to the carbon build up. If I start the car, I drive it, but moderately, and then it being shuffled around the shop combined to cause the issue. I'd say the engine is tired, but not exhausted. The mystery continues but I'll report back when I do the plugs and check distributor. Meantime what else could I be missing, I'm admittedly the "nut loose behind the wheel" with stuff like this !
Whoa! Put the tools down and back away from the car slowly....
You have found the problem... Fouled plugs. Change them and don't touch anything else. When you start shotgunning parts, you start increasing your chances of causing more problems then you solve.
IMHO, you'll find the car runs a lot better with just a plug change. Do that, get some fresh gas in it and try it. From there, you can look at the points etc.. I could make a good argument for doing a change to an electronic ignition but that's up to you and again, change the plugs first.
Everybody gives advice here to try to help, and that's great, but it can also lead you down the wrong path sometimes. There's a ton of stuff that could be wrong, but you need to apply common sense and keep it simple. Think about what has happened to your car... It sat in a body shop for a month... I'll guarantee that like most shops, it got moved around a lot.... Add to that the body shop was having problems getting it started.... That adds up to a short time of running with the choke on and then probably a lot of gas pedal pumping (because that's what happens) and I'll bet they flooded it a few times too. Guys that are used to fuel injected new cars that start right up will have problems with carb'd cars.
Thanks for that ! I appreciate all the input a lot but I agree, keep it simple for the moment, do the plugs and drive it. I would like to upgrade the ignition for sure. I tend to assume the worst on occasion as well . This car was literally in a small junkyard and a complete mess when I dragged it home.
Not running and in no way driveable but it's come a mighty long way. The engine/trans despite it all, keeps going and I've had the car 12 years. It's one tough old car, so getting plugs today, will let you guys know how it goes !
Put the new plugs in, drive it a few miles after it heats up and then pull a few plugs for inspection.
Look at an "easy one", like #3 and #4. It will take more than a few miles for them to "color", though.
Will do, picking up plugs today. Over weekend I'll change and go for a ride.
I'll be sure to update. Thanks again everyone, it's really cool to know i can reach out other people with these cars, rarely seen here is any C body, except for one lonely 65 Newport !
Maybe the body shop did foul the plugs. I doubt babying the car fouled the plugs, unless all you drives were less than 5 minutes.
I'd still check point gap and condition of points. Since you don't have many miles on the points and condenser, maybe they aren't a problem.
As to timing chain, not scary to check. Lots of slack yields poor low rpm performance
Check
1. Remove distributor cap
2. Turn crank clockwise until rotor begins to move. Mark harmonic balancer at TDC mark.
3. Turn crank counterclockwise until rotor begins to move. Mark harmonic balancer at TDC mark
Ideally s/b 5 degrees of movement between 2 marks. 10-15 degrees may still allow engine to run well. More than that, and the chain is shot.
I've never worked on a 1965, but later Non HP cam gears had nylon teeth on aluminum hubs for quietness. I had all the nylon teeth come off in 1/2 a mile driving a 1973 Monaco. Dead on the side of the road.
1965 did use the nylon-toothed cam sprocket, as did almost every engine built back then. The nylon/plastic hardens and can fissure with age, usually by about 80K miles, they are getting ready to lose at least one tooth or more. Replacing it is an "insurance" issue against it failing in the future (with all of the issues that can cause, including bent valves and a oil pickup screen clogged with bits of teeth. The ultimate insurance policy would be a double-roller timing chain set, but a normal steel-sprocket timing set can work too. In either case, be sure to douse the new cam sprocket and chain with at least clean motor oil, or even rub some cam lobe moly paste on the sprockets themselves plus the motor oil/assy lube liquid.
There can be more carbon collect in the combustion chambers from normal driving than suspected. That will NOT cause the plugs to foul, though. Getting the fluffy carbon cooked out will make things better, but the best way to get the carbon cooked out, from my experiences of being in college a 4 hour drive away from home, is just that, 280 miles of highway driving, each way. Add some Berryman's B-12 for added cleaning, too. After each round trip, our '66 Newport 383 2bbl seemed to run just a bit better after each round trip.
Pix of the Fender & VIN tags would be helpful in testing my decoder. I should be able to get most of the stuff on a '65 tag decoded-no charge ever. Example attached.
