twostick
If your car doesn't currently have power brakes, you will need to change the brake pedal too if you want power brakes.
If you want to keep manual brakes you need a disc master with the smallest piston you can lay your hands on. 15/16" would provide adequate pressure with reasonable pedal effort. I'm not sure how small you can get in a 4 bolt master cylinder but if you get the 4 bolt to 2 bolt adapter, I believe the mini van version is available in 7/8".
Kevin
Kevin
