Progrocker74
One is clearly smaller and longer than the other by 1/4 of an inch or so.
Does anyone have any ideas as to why?
Is one of my rear ends different?
I'll try to get pictures of both gearboxes for further reference.
Thanks. Helps a lot with technical details. But me being a drive train dummy am trying to do this build all myself by hand.All you need to know is HERE.
Awesome, thanks Alan. That might alleviate a few problems.Big Block/Small Block but I don't have enough data to say that definitively, that is the way it was on the three 69's I had.
They do sell a combo u-joint so you can use one with the other rear.
Alan
742 large pinion nothing wrong with that. The 1/4" in length difference is not too much of a concern but worth double checking when installed. Either will be fine behind a 383
