- Joined
- Nov 14, 2010
- Messages
- 28,348
- Reaction score
- 27,931
The last couple of these Performer series carbs I’ve bought both say warranty void if run with anything over 10% ethanol.
So, Zach how have they been running lately?
Not to hijack this thread but right now my 1406 is giving me fits. It's on my '67 Imperial. Running rich as all get out. It runs rich with the screws in any position. I had the top off and adjusted the floats to 7/16 ths hang down but it stills seems to be flooding /running rich. Choke is operating perfectly.
Any suggestions?
I think I might have it sorted... pulled the dip stick and once again there was gas in the oil about 2" over filled after about 20 minutes of run time! Ran a full pump pressure check and it was 5.5 Lbs. Pulled the fuel pump, put my fingers over both suction and pressure sides. Pumped it manually and low and behold gas came pouring out of the body where it attaches to the block! Must have been dumping gas directly into the crank case. I ordered a new pump, be here Tuesday. God I hope this is the end. I'll change the oil and filter put in the pump and we'll see.
If nothing else I've got the cleanest oil system on the planet!
What's your thoughts on going that route instead of the Eddie?I'm going to change up a little on the new engine in my NYB and going with a Holley Quick Fuel 750.
That should take care of it Kenny!
It did Bob. So far so good! I put the fuel pump in just now, dumped the oil and filter, put a new fuel filter in just because, and note she's running like a dream. The air mixture screws are even functioning now. No more shake at idle either. No black smoke and fires up at the bump of the starter! Ahhh... such a great feeling!
