Can you say glutton for punishment??
I am usually suspect when the word "epic" is thrown around. .. but it's rather spot on for this thread. Good work, man.90 hours into it.
If the spring wire burlap was pre- made, I would probably have 45 hours or so into it. I will have to go back and look at my time notes.
Working on the finer details of the rear bench prepping it for covers. I will bore you with detail pictures.
Every thing is the way the originals were.
Added “silencing”inserts to the front of the rear frame. It is to help keep the kids from bottoming out on the big bumps. Jute insulation/ padding.
View attachment 229164 View attachment 229165
This is for the person riding the hump. The foam is your only suspension.
Edge protection for the foam. The rear bench only has foam there is no cotton batting on the rear bench. Jute insulation/ padding.
Adding light canvas hog ring support strips to rear of foam. Like the original this helps keep the hog rings from pulling through the foam. Used spray adhesive no. 77 to adhere.
Its a good thing your not on the clock, they'd be working out how to replace you with a machine by now...90 hours into it.
90 hours into it.
WOW! Ninety hours so far. . . At $50 per hour, yer already at $4500, and the covers ain't even on yet. But what you have learned and the fact that some "pro" doing the job would not do it correctly the way you did, its still worth doing the job yourself.
