polara66hardtop
It is recommended to set timing and adjust the carb with all vacuum disconnected.Once that is done, if the engine acts out once you plug in the vacuum, that will tell you something.
Well I figured that, since the timing was correct before I did any of this and I didn't touch it, then it should still be correct.It is recommended to set timing and adjust the carb with all vacuum disconnected.Once that is done, if the engine acts out once you plug in the vacuum, that will tell you something.
I'm thinking a botched rebuild is to blame. My fault for not doing it myself.Yikes, If I was close I would love to look at it. It's time for a vacuum gauge and timing light. I use the light to watch what the timing does as I rev it up, and the gauge will tell me what that big gasp of air is about. Manifold on a stock engine is all about consistency. 14 Inches steady is better than fluctuating 10-18.15-16 works, 18 is outstanding. That carb Isn't usually that flighty, unless There is an Internal problem.
Have to try it tomorrow. I work 3rd shift and it's time for my nap. Thanks for the info.An incorrect carb gasket, or a PCV hose outlet. The center gasket, leave the car Idle, and spray carb clean between the top,middle and bottom, and see if you get a reaction. That needle could not be moving up and down properly. Depending on what result you get, you may have to take the carb apart. Once I found on a rebuilt someone forgot to even Install the needle in the carb.
