70NPORT
1. Correct.Gary, I'm starting to get too many variables in my head to keep track of so I need to ask some dumb questions first.
1. The starter won't spin when you turn the key to START. Is that correct?
2. Was this the reason you you started fiddling with the connector? In other words, was it not starting before the connector fiasco?
2. Week before last I noticed some of the wiring coming from the ignition switch connector was beginning to fray and some of the insulation looked as though it had melted in spots. At one point I moved the connector just a tad bit and the engine cut off. Figured then I needed to do something about it.
