Filler neck grommet install.
carguy300
East Texas
Is there any tips on installing my new gas tank grommet in new tank? Ive heard heating it in hot water to soften up or vasoline. And then installing filler neck. Experiences on best method will be helpful! Thanks again guys.
I would spray it with silicone spray. That's my weapon of choice for any rubber item as I know it will both work and not have any bad aftereffects.
I always appreciate the comments, tips, info advice. Always helps me! I think I know what the" no comments" meant in regards to installing the filler neck.....
Bevel the leading edge of the filler tube then polish the tube as far as you intend to insert it into the grommet. I install the tube before I install the tank when possible.
