bajajoaquin
I like the advice about lifters. For sure follow the advice about oiling, resting, turning, and oiling again before starting. The cam tip is a good one, too. My first (only, to date) engine rebuild was my '68 Dart GT. It made a wild clanking noise one day that turned out to be a flat cam. I didn't know that, so I rebuilt the engine, figuring I'd thereby fix whatever was wrong.
However, once I disassembled the engine, the flat lobe was immediately obvious.
If the top end was apart on your car, it might be because there was some noise. Lube up the engine, and hand crank it over, taking a good look at the cam lobes through the valley. You might not be able to see anything wrong, but then again, you might.
