superfragl
Thank for the compliments. Not sure if the bowl vent is obstructed, but will check (BTW where is vent located on Edelbrocks?). It does require open throttle and longer cranking when hot. The carb was completely taken apart, and soaked in carb cleaner can, full rebuild kit installed. I can smell gas under the hood after car sits for 10 min. I will be taking the intake off and blocking the heat cross over - what is the bets way to do this? I also made a heat shield out of thin aluminum sheet last night and will be installing it with 1/8" gasket.
For my configuration (offset inlet, center outlet, 2.5") I found only one option with 14" body length and actually ordered it at Pep Boys for $35 a piece. Will be picking up today. If that does not work I will try either Flowmaster 50 series or 70 series.
I first put the 13" Dynomax Super Turbo on my car. That was a mistake. Couldn't stand driving the car between 30-50 mph. Switched them to 20" Super Turbo and the problem went away. Using a 2 1/4" dual system.
