mr. fix it
I mean setting the timing by watching the vacuum increase or decrease as you move the distributorThe balancer has been verified when the motor was built.
By saying vacuum timing you mean setting idle advance using vacuum?
Hence it reaches the max vac at idle readjust at your cruising speed and the engine should be at optimum timing
