Formal 440 Owners. Help.
commando1
Sebring, Florida
At the front of the intake manifold, is this right?
1. Does the spark plug wire bracket go on bolt #1 (as shown)?
2. Does the A/C bracket go on bolts #2 & 3 (as shown) or on bolts #1 & 2?
3. Does the A/C bracket face as shown (pointing towards the front) or the other way (pointing towards the rear)?
I'm stuck.........:soapbox:
Unless someone else dismantled it years before and put it together so oddly you ask yourself if that was right in the first place. AMHIK
Look in your FSM , no reason to ask a technical question on the board....... Right?
Dave is on fire. All I could think of when I read Stan's first post was to imagine the ball breaking I would receive if I posted that. From whom????
Yes. That's a 74 and up only a/c bracket. And thank you for offering unlike...
Here's a '73... looks to be the same. As for the plug wire bracket, I would put the distributor in and the coil on and the placement should be clearer.
Mike or Mr C would likely give some certainty to your situation.
Where you been?
There used to be a guy here that looked up most everything, and would likely have a service manual for a Formal Chrysler.
Not sure, but I think his name was Stan... :eusa_think:
:busted: ...........................:laughing4:........... welcome back ....
