polara71
I looked at New Ramchargers there in 92 or 93'. I called there when looking for a Challenger, they didn't have the black stripe on Purple so I never went up.
Rusty floors are very common (many cars), since any water sits under the mats. If no rust-thrus, you can fix easy (wire bush & POR-15 or such), then fix the water leak - usually windshield gasket (use flowable silicone) or the wiper pivots (seal kit ~$15 ebay). A terrible thing would be a rusted out cowl (sheet metal), so look up under the dash with a flashlight.
The rust on the left fender looks benign and is probably from a crappy paint job (someone painted over surface rust?). I see wrinkled paint elsewhere, so the whole car will need to be re-painted. The main thing is that there is sound metal underneath. Look for bubbling around the bottoms of the doors and wheels. That is often a sign of rust-thru. Poke them with a screwdriver if they let you. I would probably live with the cracked windshield until I found one cheap.
Put the car on ramps and look close at the frame. If rusted thru, it would be extremely expensive to fix. You can also see any rust-thrus in the floor if you can't get the carpet up.
Overall, it looks good for a NE car. Hard to judge the price. I would talk them down because of the need to repaint. That could cost >$2000. I would do it myself. It is all in the prep and a shop hides that from you. Search for the post "paint car for $50" (or such) on www.moparts.com, using the roll & tip method. I think it is the most-read auto post ever. I did my trailer that way and plan that for my 65 Dart.
Oops. I saw only the 1st page when I posted (my browser requires scolling right to see whole page). Looks like it worked out great and you made good choices.
I agree on the comments to fix the trunk rust thrus. However, I would first use fiberglass cloth, from both sides. For small holes, Bondo Hair has chopped up fiberglass in it and works good. Without tensile strength, plain Bondo would crack. Cut away rust and wire brush to sound metal and prime first (I use Rust Destroyer). Rust doesn't spread like cancer, unless you leave loose pockets where moisture can sit under the paint.
Replacing your heater core will be a b*** since you have factory air. If like my 69 Dart was, the AC evaporator will have to come out, which means venting your refrigerant. Look up butane mixtures like Duracool. Works for me. Totally compatible with R-12 oils and even works better. The EPA has been fighting it for years due to "safety concerns" (not their domain). Butane is used in Canada and Europe. R-134A creates poisonous gas when it combusts, and is a potent greenhouse gas. The good part is your heater core should be cheap. I got one recently for my 65 Newport for ~$25.
