70bigblockdodge
That's great compression test. Is the choke on when you are having these problems? The vapor is not really a problem but the liquid fuel is a little concerning. Those Eddy carbs don't have a pull off, they just use a bypass valve in the choke plate so they can tend to run rich during warm up. I would make sure the choke thermostat is warming up with key on. You may need to adjust thermostat so it comes off faster. Should say rich and lean. Rotate it toward lean so it can come off earlier. Get it solidly warmed up and then make adjustments.
