Fuel lines
Most cars use the 2 vent tanks. I believe the smog states cali manly uses the 4 vent tank.
Thank you. I just loaded it onto my thumb drive to join the Parts Book on it.
Now here's the reason I asked:
And my parts book is very vague in that area:
I think the reason they did that was to not use a vented cap so that gasoline will not spill out on a hard launch as fill tube is at rear. Just saying, I don't want to see you pulling away from a light dumping gas on the ground and lighting up one of the local blue hairs in her caadilac.
I drilled a hole in the cap for the mean time. I found the correct vent tubes and grommets and they are on the way.
