Thank you. It may be a while before I can work on it again. I started it up today. I got to tell you it sounds strong. This guy I got it from used wire ties on everything. The car is held together with wire ties. That's what I will attack next. Then a header leakKeep up the Progress Bob. I like inspiration to get me involved in Drag racing
I still have stuff to learn and enjoy seeing you work on this car.
Must be a truck driver. Lol. Your makinge jealous with the seat low and back.This guy I got it from used wire ties on everything. The car is held together with wire ties.
I got a new one from Rockpepadvancezone and I had no problems.View attachment 90234 Ok so the header on the pass side is rubbing the collector. So I took the header off. I'm under the car pulling it out & notice the trans mount is bad & has a lot of sag. So I figured that why it's rubbing the header. Went to Advance Auto & got a new Chinese mount (I kbow) & took the old one out easily. The through bolt won't go in the new one. Hole is too small. So I thought I was going to get this all done today. Guess not.
Sweet, when is the big block going in.Very good driving position. A little low which I like. I can reach everything easily. Done deal
its already got a big block in itSweet, when is the big block going in.
Yes. It's called unistrut. It's quite strong. All the edges are rolled for reinforcement.The one inch tubing looks like the perforated stuff they make racks and sign posts from. It will work fine, just don't think he drilled all those holes himself.
Will Bob be enjoying the drill? Or does Bob have a replacement in the collection?
I'll get another chance to use those expensive cryogenic drills I bought. Notice I didn't say drill bits. I have been educated. The frustrating thing is I seem to take two steps forward & one step back. I have been bragging all week about how close I was getting this car to being ready for a TNT & this happens.Will Bob be enjoying the drill? Or does Bob have a replacement in the collection?
Either way, it's a PITA you didn't need.
