Do as I do. Buy yourself a small SPOOL of fusible link wire in the size(s) you need. I use #12 with my 60A alternator, which I've wired in #8 AWG from the alternator charging post to the fusible link, cut to 6" under insulation, + an additional .5" stripped at each end for termination. I use a split bolt to attach the #8 to the fusible link, which is snugged down firmly to the universal terminal along with the starter wire and the fusible link going to the #8 leading to the starter relay, then the dashboard. Each split bolt connection is first rubber taped, then vinyl taped and finally friction taped over for mechanical strength. This is the standard procedure for taping split bolt terminals BTW. Mine are bronze. I pay about $5.50 for 12 feet of fusuble link #12 AWG for that #8 wire I run the 60A circuit in. This accomodates charging and ALL of Mathilda's electrical loads aside from the starter.
NO NOS ripoff prices!
NO headaches from searching all over Creation for the original termination links!
ALL mine are 7" total length, w 8" insulation. I use 1/4" ring terminals to attach the links to the battery terminal. Its the best spot for them. When I've had short circuits, the links melt nicely, protecting the alternator AND the dashboard circuits, starter and horn relays, et cetera, and I can replace them quickly, easily and be back on my way. After a NASTY fire resulting from my alternator stud shorting when the case cracked last spring, I made damned sure my main power circuits were WELL protected.
Of course, my wiring won't pass muster with purists for being like the original stuff, but Mathilda is a daily driver, NOT a bauble.
