Gas Gauge Not Working
This type of strap was used from 1962 to 1976 on most mopars.
You can just twist some #12 AWG wire around the sending unit, then bond it to the sheetmetal frame OR, if you're "smart," a front to rear bonding jumper which will connect everything along its path directly to the battery cathode. This practice helps overcome rusted contact points between sundry sheetmetal body portions, and in later models, those portions mechanically insulated by rubber.
That clip can be found on eBay.
LONG Fuel Sending Unit Ground Strap Fit Cuda GTX Charger RoadRunner Duster Mopar | eBay
