The sages of C-bodies to the rescue once again!
thank you @Ghostultramarine for getting this topic going. I had all but given up on my gas gauge. But after reading this and doing a bit of looking around, I think the missing ground strap at the tank may have been my (main) problem.
squeezed under the rear of the car today and sure enough, no ground strap:
I also happened to notice that the sender wire was also just barely hanging on (that’s why a referenced main problem).
Jacked up the car and put it on stands. Got some wire and electrical tape. This is just a temporary fix to see if indeed this was the issue:
Turned the key to on and viola, my gauge is working! Going to run around town in it for a bit and then top of the tank to see how close to calibrated it is…. But calibrated on not, something is better than nothing. I had had nothing!
thank you!
thank you!
