65sporty
have you driven it much yet this year? how is the EFI working out?
I have driven it very little because it runs like ****.have you driven it much yet this year? how is the EFI working out?
I went by my motto "stock is best".Right now I'm glad I kept my TQs, they've continued to be great this summer cruising season..
Here's the kicker: It ran like this with the stock carb and with the Eddie and with the EFI.
It runs & smells like it's super fat. It's definitely spitting water but there's fuel in it.
I'm gonna pull plugs & check compression next but I'm wide open to suggestions.
Water coming out of the tail pipe of a car is normal. Since water is a by product of the combustion process.
A compression test is order. Which you're going to do. Then check and make sure your ignition system is up to snuff. Lastly will be fuel. Do you have a fuel pressure regulator on the car? If not you may want to install one so you can rule out too high or too low fuel pressure. Since it runs basically the same with stock carb, an Eddie and EFI. They aren't the cause. But something common to all 3.
It would have to be two bad valves since it spits out both tailpipes.Just a guess, but I'm thinking sticky/burnt exhaust valve...
