Wasn't there a guy many years ago who did that? I remember it because all the mods that were done to get it squeezed in there which really surprised me
(Sent using Forum Runner)
I did hear of that story and also a story about 1 of none Chrysler 300 that left the factory with a Hemi.
[h=3]The Chrysler 300 with 440 Hemi (by Curtis Redgap)[/h]
| 1970 Street Hemi | 10.28:1 compression |
Horsepower (gross) | 425 @ 5,000 | |
Torque | 490 @ 4,000 | |
Carb | Dual 4-barrel Carter | |
Intake/exhaust duration | 284° / 284° | |
At one point, serious, and I mean earnestly serious consideration was given to having a Hemi 300 engine. This would have been an exclusive engine just for the Chrysler 300 letter cars. With the introduction of the 413 wedge, it was well documented, thoroughly panned, and argued by a lot of purists that the 392 Hemi turned just as much power, and a lot more power was available but not utilized before the Hemi was tossed out. In all fairness, the
413 Wedge was the better torque producer, along with a hydraulic lifter set up for the valves for less intense maintenance. Until you got past 100 mph, the 413 was marginally faster than the 392 Hemi.
One of the spinoffs from the A990 full racing Hemi program that was built and tested but not produced was the 300 Hemi model engine, meant for the 300 letter series
sport sedan
cars. 440 ci was obtained by boring the 426 block to 4.32 inch from the 4.25 inches. The 3.75 inch stroke remained the same.
This particular engine was designed to accept the two bolt main bearing cap structure as well as not having to go through the lengthy and expensive bake out heat treatment. It was slated to receive one of the first triple carburetor setups, as well as a 268 degree hydraulic camshaft later to be seen on the 440 Six-Pak cars. It would have used the cast iron heads, so the valve size remained the same with an intended 10.25.1 compression.
Horsepower
may have been slated for around 455 or more. It was never dynoed, so figures are not available. Of the many 426 Hemi engine variants this was the
only one that got two main bearing cap bolts.
Following are some of the specifications from the white paper, written for John Wehrly by Bob Rodger, father of the 300 letter cars, and by product planner Robert Cahill.
Mr. Wehrly had joined Chrysler in 1962 and quickly moved up to become supervisor of racing engine development in 1971. In 1964, Mr. Wehrly was heavy into the Hemi development for the Daytona 500. In 1965, after NASCAR moved to ban the Hemi and Chrysler staged a complete boycott of the NASCAR circuit, Bob Rodger and
Bob Cahill, sensing that NASCAR would not ever relent, moved quickly to push the 426 Hemi engine into a regular production model available for the street to anyone with the cash to buy it. The letter follows:
Description: Because of continued requirements for an ultimate performance drag strip and street usage type engine with expanded usage, the following change is the engine lineup has been agreed upon after discussion with the affected areas. Please release a
hemispherical combustion chamber
engine for "B" Series with the following general characteristics:
- Intake manifold to have two four barrel carburetors.
- Cylinder block to maintain cross tie bolt bearing caps.
- Cast iron exhaust manifold.
- Solid lifters are acceptable but not preferred. [Hydraulic lifters were not achieved until the 1970 engine - ed.]
- Pistons - forged acceptable and thermally controlled preferred.
- Manifolding and camshaft to be designed to give the best highs speed power possible while still maintaining a reasonably drivable vehicle for summer and winter.
- Automatic and four speed [manual] transmissions required. 4-speed to receive development priority.
- No air conditioning required for "B" series.
- Limited warranty is acceptable for the "B" series.
Projected production volume expected is between 5,000 and 7,500 cars, which will take effect in the start of the 1966 production year. This engine to replace the eight barrel wedge requested in Production Planning Letter of 8/5/64.
The above letter was dated January 6, 1965. On January 12, 1965, an engine production letter was issued for the A102 engine. It listed all the items needed to bring the race Hemi engine to specifications for use on the street.
Mike Sealey wrote: There is a 1966 Chrysler 300 out there with what appears to be a factory-installed 426 hemi, something most historians say never happened in C-bodies. According to Chrysler historian Jeff Godshall, last minute reconsideration was given to discontinuation of the letter series 300 after the L in 1965. A tentative plan was drawn up for 500 1966 300-M models powered by the 426 hemi, but was withdrawn when marketing research suggested there might be a problem selling even that small a number for the price
