CanCritter
to much schoolin...my head hurts.....found this...refrence….is pretty close to my setup
reference…..
quote"The modern equivilent is the Sealed Power cast - they have a compression height of 1.990. If you use inputs of '70 build specs (meaning blueprint deck height, steel head gasket, blueprint chamber size) it will come out around 9.5:1. If you go with reality using the available composite gasket, a deck height of 10.735, and chamber size of 88ccs (which I've found to be potentially smaller than what is in one's hands) it's closer to 8.6:1. Personally I would use a more performance oriented piston. The KB Hypers are great value provided you or your builder can follow directions.
1970 440 Piston Compression Height?
Unquote"
l can live with 9.5.1....anything more would be pushing it with iron heads lm thinkin...ie fuels ect...more readin to do...
compression ratio...
1am.....think l have it sorted l think...….
bore...4.320
stroke...3.75
CC 84
deck clearance...5.64 or 0.078125
piston compression height 1.991 flat tops
piston head volume 0.00
using summits tools..
Compression Calculator
leaves me with this
gasket..
.020.... 9.37.1
.039....9.03.1
.051....8.83
sooo if l have .079 below deck + .020 gasket gives me basically 100 ?
...do l need to raise this..or lower it for proper quench??
...is 1.10 am and am completely lost...folks do you know where yer kids are?
thoughts, corrections,swift kicks welcome....
man I need to get to bed....so specs tell me l should be 0.035 - 0.045 in. for proper quench so do l use thinner gasket?...
think l need to recheck my deck height tomorrow..am takeing measurement at side of cylinder...will try to get a readin in center of piston tomorrow...
..that's it lm toast....niters folks
906s on the newyorker was at 9.78.1...am gona have nightmares
reference…..
Unquote"
bore...4.320
stroke...3.75
CC 84
leaves me with this
gasket..
.020.... 9.37.1
.039....9.03.1
.051....8.83
