Fireguyfire
I’m going through the electrical on my 70 300 convertible; the previous owner had removed the factory wiring and added an aftermarket harness that lead to only half of things working, etc.
I’ve tested and reinstalled the factory wiring harness, and am reconnecting things back up as per the factory.
My question is regarding the heater blower motor that is located on the heater box on the upper inside of the passenger side fender near the power antenna.
There are 2 wires that come from the blower motor; 1 black and 1 red. The black goes through the firewall grommet and grounds to the inner firewall; the red goes through the firewall grommet and was cut and hanging by the passengers feet.
I’m assuming this red wire from the blower motor must go to the blower motor switch? All of the connectors are used on the heater blower switch connections, so I’m guessing it should tie into the factory harness somewhere behind the glove box? I don’t see any cut wires in the factory harness.
The shop manual wiring diagrams aren’t helping me, so I thought I’d ask here and see if o e of you C body gurus can help me out with where the red blower motor wire should go.
