Still the dang best thread for power window motor repair!
Thanks Mr. C!!!!
Thanks Mr. C!!!!
Please read the FSM before doing this....
Don't unbolt the wiper motor from the regulator until you have drilled and bolted the arms together on the regulator. You could lose fingers and or seriously injure yourself when that regulator spring unwinds.
Yes i've found that motor,but my ones are works good and i don't want to buy new ones.I have not seen just the gears available . I bought rebuilt motors and used my old gears which were still in good shape. Other guys have used these motors, in theory the gears should work, but if it was me I would just replace the whole motor. Dorman Power Window Motors 742-301
Had to share that the one motor I fixed using the 1/4” nuts years ago quit working a few days ago. The window quit halfway up but I could still hear the motor click so I took it apart and replaced the nuts with the delrin rollers mentioned above and it’s back in action. I guess the nuts got worn to the point they were causing it to jam? Anyway while I had the door panel off I made some needed repairs to the panel as well as repainted the black parts and started to refinish the wood. Still more to do but I only had a few hours to do it so I had to pick and choose just how much I tackled yesterday.Got them today. Perfect fit!
So... that means the Fords used the same rollers.
These were $6.99 plus shipping for 12 delrin rollers. Nice quality and cheap enough.
(12) Ford Lincoln and Mercury Power Window Motor Gear Delrin REBUILD Bushing Kit
I don't think you're going to get the motor out without the regulator, so you don't have to clamp it until you are about to remove the motor. Unless in your Step 2.5 it is remove both regulator and motor from vehicle and Step 0.5 or 1.5 is to undo the window from the regulator (that's what I've done - and clamped it with a wood clamp so it does not fall down).hi all, newbie to this very informative forum and searching for some guidance. i was searching B body forum but this thread was the best i found. I have a 68 satellite convertible and i am having trouble with the drivers side rear power window. Its stopped about 3 inches down. based on what i read it seems it could be the issue with the "pucks" but i want to take it out and see (motor runs just no movement of the window). but this leads me to my question related to taking the regulator out of the door. is it the four bolts (two bottom, two directly above) pictured by the motor holding it all in? from what i have been reading (thanks bajajoaquin) is 1- hold the window in place. 2- remove regulator (4 bolts?) 3- clamp regulator preventing spring from springing. 4- remove motor and fix if needed. I attached a picture hoping someone could confirm or guide me on the correct way. there isnt much room in there and i dont want to make a mess of it.....but excited to try.... thanksView attachment 543888
Your car will probably have the drive with the springs rather than the pucks. From what I've seen and read, 1974 seems to be the year they changed, but I could be wrong.hi all, newbie to this very informative forum and searching for some guidance. i was searching B body forum but this thread was the best i found. I have a 68 satellite convertible and i am having trouble with the drivers side rear power window. Its stopped about 3 inches down. based on what i read it seems it could be the issue with the "pucks" but i want to take it out and see (motor runs just no movement of the window). but this leads me to my question related to taking the regulator out of the door. is it the four bolts (two bottom, two directly above) pictured by the motor holding it all in? from what i have been reading (thanks bajajoaquin) is 1- hold the window in place. 2- remove regulator (4 bolts?) 3- clamp regulator preventing spring from springing. 4- remove motor and fix if needed. I attached a picture hoping someone could confirm or guide me on the correct way. there isnt much room in there and i dont want to make a mess of it.....but excited to try.... thanksView attachment 543888
Sorry, I did not get a notice to this thread and I looked in the book and could not find the same page I am SURE was in there ...Looks like i have the same type SpitFire had a page back.. anyone know if they still make replacement gears? i havent found a source yet.
