Maxdaddy1$
Can you provide any details on how to remove my buckets to take them to a seat shop?
Thanks
Thanks
There are four studs per seat that go through the floor. The studs are inside of the floor supports. Just remove the 4 nuts per seat and they will lift out.Can you provide any details on how to remove my buckets to take them to a seat shop?
Thanks
Are they studs or bolts?There are four studs per seat that go through the floor. The studs are inside of the floor supports. Just remove the 4 nuts per seat and they will lift out.
Yes.So, nuts are under the car?
Many thanksYes.
There will be 4. 1 on each corner of the seat. IIRC, the nuts take a 1/2 deep socket.
Best way to see where they are is look at the seat frame and visualize where they stick through the floor.
I have long arms, so I can reach the nuts without jacking the car, but if you are reluctant to jack it up and crawl under it, drive the front wheels up on something like some pieces of 2x6 wood or similar. That will get it up just enough to get under the car and unbolt them.
I wish I had a good pic to give you.
Where are you located in PA? I'm in the Northwest corner.Many thanks
That might be your only solution.I have my seats adjusted all the way back and still it feels not comfortable. Has anyone invented a Solution to move the seat Tracks 2“ back . I can do the hillbilly Solution and just drill 4 new holes but I‘m not sure if this is still a solid fix for the seats...
Don't drill new holes. It's a bad idea. The floor is braced in the mounting spots for safety and if you're a big guy, that's even more important should you get hit, especially from behind.I have my seats adjusted all the way back and still it feels not comfortable. Has anyone invented a Solution to move the seat Tracks 2“ back . I can do the hillbilly Solution and just drill 4 new holes but I‘m not sure if this is still a solid fix for the seats...
