I had my tank reconditioned and I thought I would install the tank today, because I finished a job early near my shop. I had no luck. I will admit I did have a gasket going from the neck to the tank backwards nearly the whole time I was trying to install it.
I wasted so much time I wanted to see what the best way to do this. Should the tank already be mounted in place or just raised and mount it after the neck is installed? Any tips would be greatly appreciated. Am I crazy or did I read that someone put a difficult rubber gasket in the microwave to warm it up?
When I removed the neck it was really tight and I said to myself at the time, this is going to be a pain to reinstall, I definitely had that right.
