commando1
No, even off a junk engine they work great.
Well, aren't YOU becoming the facetious one now....
I may have a very simple solution if it is a very simple problem, which from your original description it does sound right.
Take out your mixture screws and blast some compressed air through the ports, then reinstall your screws to your initial 2 turns out. You will know in short order if this worked and you can then do your final adjustment when it's warmed up.
It may sound dumb, but it has happened to me 6-7 times as I have quite a few vehicles that get run infrequently. It is just some little fliggin that gets lodged in your idle circuit, and everything seems fine just above idle.
If we are taking votes here I like the the AFB/AVS style carbs the best for most places, as they don't have any gaskets below your fuel level that can cause your carb to leak, as with the Thermoquad also. In my experience I have just had less trouble with the Carter based carbs.
One thing I suggest with the AFB/AVS is that you run an isolator to keep it cooler, so they start better when hot.
If you want all out performance for a street/strip car, the HP series Holley would be my choice.
Oh I don't know, I find it rather witty.
Now as far as the warning, are we talking lug nuts, wing nuts.... lock nuts???
WOT is still nice however I cannot get the carburetor to idle worth a damn. After a few moments at a stop lights it will idle like a cylinder is dead. When I get back on the interstate and get the mph's up this condition clears up completely. :icon_study:
Just trying yo keep this forum at a higher level than Moparts where you all too often see:This is a car site keep using words like that and someone is likely to kick you in the nuts. :wav:
"new breaks...", or
""needs restored...". :tied up:
But Stans not a stand up guy........:Groaner:
That settles it. I'm NOT picking up your beer tab....
Oh. Sorry.You cheap SOB since I dont drink my previous statement applies
your engine guy is correct. eddies are cheap. they look nice but thats about it. run a proform if you can afford it . they are in my opinion the best carb on the market . basically a holley with balls.Negative on the cam, car is 2bbl 383 from the factory, it is rebuilt with 383/440 magnum spec cam thrown in for starters....and the carb is an electric choke model (edlebrock "thunder AVS" model). I have the Ebrock tuning book, but it might as well be in Swahili with a martian dialect....I NEVER read stuff like that -- if I do it just gets more confusing. I like to do things by my eyes, ears, nose, and sometimes even..taste (don't ask).
I was just talking to a local mopar engine builder here who builds for street/race and race/strip applications this morning and he says Edlebrock carbs are junk: you can either get them to idle nicely OR to WOT nicely, but you can never get them to do BOTH nicely at the same time. He happens to run a 72' Dodge Dart w/ stout 383 and 67 Coronet w/a forged crank 440. He switched both cars over to Holley carbs and then shopped the jetting work out to a carb specialist...has no problems whatsoever with them in that area (induction)....thinks I'm wasting time with the Ebrock setup....nice to hear, of course. If ONLY it would idle like it WOT's the world would be a nicer place.
A few weeks ago I bought a brand spanking new Edlebrock 650cfm AVS carb to go on my 383. Did the install, everything went well on start up: no erratic idle, no vacuum leaks, no fuel leak or smell, yada yada, and WOT down interstate 295 are beautiful (every time). Fast forward to now: WOT is still nice however I cannot get the carburetor to idle worth a damn.
...this problem has gradually crept up to the point its a real chore to keep from shutting down from the poor idle at stops.
Wow,somewhere along the line this turned into a holley vs. edelbrock vs thermoquad battle and you still aint solved the problem.As far as the guy who said all edelbrocks are junk, that just means he has little knowledge of carb tuning(since he sent his to someone else to get jetted I'm guessing he doesn't understand Holley's either) This problem is just like any other,a simple process of elemination. No carb can just be bolted on and run its absolute best. I agree with taking the idle mixture screws out and blowing some air through to clear them(dont shoot 120 lbs of air in there) Does your car have a fuel filter? You might have some foreign matter in your jets. There are tons of little things that can cause these problems you just have to work through them one by one.
